F12000
Everything posted by F12000
  1. F12000
    Kfx shocks
    Hello, a friend of mine tried them with aftermarket A Arms, and were more stif and soft (depends your regulation) than YFZ shocks, wich worked perfectly for Superquads racing, a little bit longer i think, but great shocks!
  2. OK, but Hot Rods in 450 engines are not good at all, they last half of the hours the oem do, so, which are the best rods? versah? IMS? or i should go OEM? are aftermarket lighter and stronger or are just the same? Thanks!
  3. Yeah, that's what i want, an everyday banshee with some pepper on it... as we run for hours when we use it, i want something that last... Thanks
  4. Hello, i have a 98 banshee with fmf pipes, vforce 3, boost bottle, K&N air filter (ebc dirt racer clutch, yfz 450 shocks, custom made a-arms, hiper racing wheels, maier plastics (front) DCS (argentinian) foot pegs) and stock pistons and connecting rods. I'm from Argentina, so i will not go stroker. As the engine is as it comes from yamaha in 1998 i was wondering it may need some rebuilt. it runs ok, but i think it could be better... The question is: wich connecting rod do you recomend? OEM (yamaha genuine) Wisecco any other? I do not care if ones are a couple bucks more than others, as i want to do this only once... Also i'm going to run wisecco pistons. Thanks I forgot, my use is for dune riding and some MX, not race, more recreational, but i like to hit the gas and have what banshee's have, power!
  5. Can you contact me at [email protected] ? Thanks
  6. Hello, is it possible to install a rear shock of a YFZ 450?? any pics? Thanks!
  7. Hello, does anybody tried the KFX shocks on a banshee?? Because seems similar to yamaha ones but much more thinner on the lower part and seems that no modification is needed.
  8. I did, but i havent found it.... i'll keep looking, Thanks
  9. Hello people, has anybody tried namura pistons??? It seems to be a great piston, with teflon paint over friction points of the piston. If anybody has this pistons or at least knows something i will apreciate! Guillermo from Argentina.
