phrog70
Everything posted by phrog70
  1. lets ride eghh. lol
  2. the three arrows are not that inportant if you look at your inner basket there are little dots and i beleive there is one finger that has three or two { it looks different} i always line one of the arrows up with it just make sure u get it all flush and lined up. easier to do then explane. if you still need help let me know and ill call u and explain it.
  3. i got both types of carriers and if u are not change sprockets alot(in sizes) the standard carrier might be alittle harder to line up but works fine for one of my drag bikes. i do like the round carrier too but ya you are going to pay for it to . good luck and make sure you get a nice one
  4. hey im interrested in the tye rods pm me and how u want paid thanks
  5. if you are running stock carbs you might want to check your needle position first 300 to 330 should be fine if its a stock motor with mild stuff. if you are running dyno jet needles they need to beset in the fourth notch from the top of the needle for glamis and your air mix screw should be one half turn out. if you are using 360 you ether have a air leak or alot of motor i guess i just put the same set up together last night for a customer and hes running 280 on t5s no porting
  6. phrog70
    billet peices
    im looking for some good billet pieces for the banshee. i need a waterpump cover smooth no design and a case insert smooth no design if you have something laying around let me know how much before i order new thanks
  7. sandblasting is fine . i would try and use a fine course sand, so its not that rough. as far as painting it with pj1 paint u might want to use a primer under it first and it should be fine just give it sometime to cure out before you go messing with it. dont forget to use some type of cleaner or tac rag before painting. u can pick them up at a napa or parts house . well good luck post pics when done
  8. first time useing a terry cable set up. put cable in on banshee and sink carbs but cable pulls real hard. checked for binding but everything looks ok. never had problem with motionpros cables. just thought maybe i missed somethimg
  9. if you still got then ill take them
