banshee440
Everything posted by banshee440
  1. Looking for a water temp gauge for the shee... Who makes a good one or has any one ever made there own?? Thanks
  2. Will you sell just the filters and outerwares?? and if so how much to 48759 MI.. Thanks
  3. Ok thanks Darthwall but how can i tell if its been ported or setup for a strocker??
  4. Ok a friend of mine gave me these stock cylinders that have a big bore sleeve put in them and it is 69.50mm and the sleeve it self is still really thick it is 0.185 inchs these are ported not sure by who or how much but they look nothing like my stockers in the ports.. Where do i get pistons for these or can these even be run??? I'm new to this big bore game any help would be great.. Thanks
  5. Ok thanks J-Madd thanks for the very quick info....
  6. Ok thanks a ton J-Madd But whats the ring gap and tolerance suppose to me it's all new to me thanks...
  7. Ok heres the deal my cylinders are 65.93mm and 65.98mm so what size pistons do i need to order 80 over???? I feal dumb but i'm ordering them today and i dont want to mess this up... Thanks a ton guy's...
  8. Ya i played it on x box but its is by far the best atv game yet.. And yes you can mod your quad from the frame up.. There are banshee's honda 250Rs and all the new 4 strokes.. Awsome game
  9. Thanks for all the quick replys guy's..
  10. PM'D Ya
  11. As far as feshened up you mean they need a bore or a hone?? And are the stock porting..Thanks
  12. Lookin to buy a basket and inner hub or a whole clutch setup..Thanks
  13. Thanks again guy's...
  14. Ok any one got a number for f.a.s.t or any michigan builders.. Thanks
  15. No i don't have pistons for them but the guy i got them from said they had 69mm sleeves in them and they were ported to match.. But had no clue on what stage porting was done on them...
  16. Ok so as some of you guy's already no i'm starting to put my blown up mess back together.. I'm starting with stock cases a stock crank not welded and now i only need cylinders so i was gave a set of 69mm bore juggs wich i can tell they are ported not sure how much but a noticeable amount more than my blown up stockers.. So here where i'm stuck what am i goin to have to do to run these big bore juggs that are ported i have stock carbs a noss head that i no i need big bore cut domes for but what are the pros and cons?? What size carbs? what cc for the cut domes? i'm 500 above sea level and i'm stickin to pump gas.. I'm sure theres tons i'm missing so Any input would be great Thanks again guy's...
  17. Thanks for the info Machwon.. But why stay away from the 69mm jugs just wondering??
  18. Ok thanks alot for all the help guy's.. I have another option now found a stock welded crank and a set of stock jugs bored out to 69mm and the jugs are ported now sure how much but u can tell they are carved out alot more than my stockers.. If i run these what will i have to do as far as carbs and any thing else i'll have to change thanks..Matt
  19. Thanks for all the info guy's the strocker crank comes with a stocker plate if i use that will i still need the cut domes?? If the money is there i want to get some porting too i ride on our own track and do a lil hill climbing and sand draging at silver lake what kind of porting would you suggest and who should i get do the work?? Is there any one in michigan that does good work?? Thanks
  20. Ok so heres the bad news my 02 banshee lost the left cylinder wrist pin bearings and it destroted my top end and split my stock crank apart.. So i'm thinkin of goin with a 4 mil stocker crank kit but i no nothing about the pro's and cons of running a stocker crank i want to run stock bore or maybe 40 over to clean up my mess i have a noss coolhead with 21cc domes and v force 2's fmf fattys and my timeing it plus 4 advanced and also i'm running stock carbs with a k&n.. I geuss what i need to no is what you guy's apinion is sould i go stock or should i go 4mill and if i go 4 mil what do i have to change or what route shoud i go...Thanks in advance..
  21. PM sent
  22. Looking for a stock bore stock port left cylinder for the shee...Thanks
  23. Would you be willing to sell just the left cylinder?? And how bad are the scratches that you say it may need a bore??
  24. How much for the left side cylinder i'm interested... And are these stock bore and stock porting??..Thanks
