Ok so what is the most hp u can get out of a stock motor? Im just curious because mine made 82 hp on the dyno. I thought it was pretty good for a stock motor.
Ran that crank for 2 years and what I meant by piston failure was that half of the bottom part of the piston is gone.. and when i pulled the pipes out of the right side a bunch of metal particles started to fall off.
Ok so this is really odd. My piston blew up on the right side but the crank bearing went out on the left side?? Normally wouldnt it happen on one side? Also what might of caused it, because the jetting was perfect.
Ok so my stock crank recently went bad. I was going to upgrade to a 4mill but I was wondering do u have to do any case work or cylinder work??? Oh and Im running stock cylinders.
