Alright guys, looking for a little bit of help here. What I have is a 96 Banshee that I have owned for about 6 years and ridden the hell out of it but it's been kept up nicely. Two years ago I was riding it in the snow and in one area it got deep (about 9") and I had to rev the hell out of it to keep from getting stuck. I wound up overheating it to the point that it melted a piston due to the high revs and low air movement through the radiator (I know it was stupid!). So anyway I took it apart and it sat that way till last month when I got new .030 over wiseco pistons and had my cylinders bored out. When I got it all back together it started right up but boggs when you try to give it throttle. The banshee has stock pipes, stock carbs with the TORS crap still on it, bored out .030 like I said with fresh pistons and rings, has aftermarket reeds on it, K&N filter in the stock air box, new plugs and so on. When I first started I thought it would be an issue with the carbs because it sat for so long but once I took them apart I found that they were nice and clean but I took them all apart anyway removed the needles and jets and cleaned it all out. The jets appeared to be all stock. It was hard to read but It said 220 I think and had the needle clip in the third position which is about right for a stock set up according to the owner's manual. Put fresh plugs on it and it still runs the same. The carb slides appear to be going up and down in sinc ok. So here are the questions I have:
Is this the typical TORS issue that you see when you have a problem with that? If so is there a way to disable the TORS system so I can verify that is the issue before I go buy a TORS elimination kit?
Another thing too I read something about the parking brake switch being a problem on these sometimes but where is it located? I looked at the clutch pedestal area where the parking brake cable to the back brake comes out of and I don't see anything there.... The wiring diagrams on line do not show it to be a part of the TORS system.
What other things besides TORS could be causing this?
Sorry to be so long winded but figured that a good description of what happened and how the Banshee is equipped might get me a better answer. Any ideas you can share from your experience would be greatly appreciated. Thanks in advance!!!
