Yeah it's not a banshee but it's close. I pulled my 85 rz350nc(9993 miles on the clock) out of storage and cannot get it to run right. This thing ran great a few years ago. It bogged and died on me within a 1/4 mile and would not restart. It is all stock except for possibly the reeds. Are the stock reeds metal? The bike starts on the first kick with the choke on when cold. It idles at 1200-1500 rpm for about a minute then the idle lowers a little like it wants the choke off. That seems normal to me. It all goes wrong when I turn the choke off. It seems to idle just fine for 15-30 seconds then the idle starts to creep up to 2000-3000 rpm. Also it does not rev out very clean. When I whack the throttle wide open it gets to around 9000 rpm, then cuts out and continues at 9000 rpm.
It sounds lean. Maybe starving for fuel, or has an air leak. This is what I have done so far:
new plugs(br8es)
cleaned the air filter and checked the air box
cleaned the carbs(twice)
checked the float height(good)
no gas in the floats
checked the float bowl fuel level while running the engine(good)
pilot screw is 1-1/2 turns out
cleaned the fuel tank(found some particles)
installed a fuel filter
ran the bike with the gas cap and vent lines off(no change)
replaced the carb joints(the originals were cracked,no change)
replaced the reed block gasket(reeds are good, no change)
If someone with banshee or rz knowledge could respond I would be grateful. I have worked on my own two stoke dirt bikes, so I am not a complete newb. This bike has me stumped.
Thanks in advance,
Chris
