crombie
Everything posted by crombie
  1. i have taken my rear axle of to fit a twin bearing carrier and notised there is some back and forward play on the splines for the disc and sprovket hub. is this normal or is it a bit worn. i was hoping it would tighten up when i refit the axle and tighten the hub nuts
  2. I have got the swingarm and linkage of to replace all the bearings and fit a twin row bearing carrier. im wanting to get all the bearings fitted as soon as they arrive so i ordered a chain slide that opens up to fit
  3. do you have a pic of one fitted. does the swingarm need removed to fit it
  4. hi all. my swing arm chain slide has worn thru and come of so i need a new 1 but im not sure what they look like so i dont no what to order. does anyone have any pics or links. its the one just after the front sprocket
  5. the new carrier comes with a grease zirc. it looks like the damaged bearings have caused damage to my sprocket carrier. ill put a pic up tomorro for you to see
  6. Hi everyone. im new to the site and already having problems. i have just bought a 2005 banshee and already the rear bearings and carrier has colapsed. si i took it all apart and discovered the swingarm , shock and linkage bearings are all needing replaced. bad times . browsing thru ebay and came across a twin bearing carrier, is this the option i should go for, 4 bearings must be better than 2.when iv replaced the whole rear end bearings i need to do the fron A arms bearings, more bad times. shame as its a really clean quad
  7. what is tors and what does it do. its actualy warm at the moment up here plus i live to high up in scotland for tartan. all i see when im out riding is deer and hill walkers
  8. hi all.im from the highlands of scotland. im new to the banshee world and this seems to be the site to be on. i have just bought a 2002 banshee that is standard. i use it for forest tracks and long distance runs and use it for fishing. im looking at getting new exhausts for it. thinking of a fmf system. what other sort of parts could i buy to get a little more speed/power out of it. also 1 question about the thumb throttle. mine has a little switch inside it, anyone no what this is or does
