3 stroke
3 stroke's Achievements
  1. all electrical is new, wiring harness has been taken apart and inspected, swapped all parts one at a time from old to new and back (stator, coil, regulator and CDI) with no change. also i noticed the pipes are starting to discolor from heat(cpi in frame) so i don't think im too rich, if anything i'm lean. . . .thanks for the input
  2. I'm pretty sure, i had timing at +4 and it ran like poop at top end pulling a hill, advanced to +7 and it all went away. . .i did noticed that with a low load(flat land) 3/4 throttle high rpm it didn't sputter. BTW I'm running 35 mm pwk's with a 155 main
  3. most stroked shees are running a 14 41 to 43 gearing. 17 seems a bit high for a banshee that has 6 gears :biggrin:
  4. just got my cheetah cub with a 4mm crank together running 111 octane and 19 cc domes, runs great at low to mid range but cuts out at top end unless i advance the timing +8 degrees, is that safe or do i have another issue? . . . . need input, thanks
