Mike Z
Mike Z's Achievements
  1. I have a Wilburn Ignition for sale. I helped develop and tested this ignition with Chuck Wilburn. I have multiple flywheels and know how to program this ignition since I helped develop it. I do not frequent this forum often so if anyone is interested, please email me at [email protected].
  2. See, most people take my replies wrong. I wasn't trying to condescend j-madd, I was just merely saying that it does. I guess the huh at the end might have made it sound bad, but I was just saying that it does. And I can tell you with 100% certainty is that the only thing that will break a plug while it is in the motor, is detonation. One of the reasons spark plug are made out of porcelain is for that very reason. You can through it at the ground to try to break it and I bet you will quit before it breaks. But don't listen to me, I'm just a know it all A$$hole that knows nothing even though I have blown up and built more motors then most members age on this site.
  3. Based on the information you gave, the motor is definitely detonating because that is the only thing that will shatter a plug. If it is something that has just developed over the years, then more then likely the problem is an air leak. If you blipped the throttle, would the rpms comes right down or do they come down slow? The first test I would do it to see if there is an air leak. This is very east to do with just a few parts. First you will have to remove the pipes and carbs. If you have a stock bumper, take the rubber ends off and bumper, get a hose clamp that will fit over it and then put those ends on the exhaust flanges making sure to tighten down the hose clamps. Now go to your local hardware store and by a set of electrical pipe ends that are close to 28mm or 1 1/8" inch. You can also use a PVC end that also has an OD of 28mm or 1 1/8". Now buy a schrader tire valve(the kind that have nuts on both ends and then drill a hole in one of the caps you bought to stick in the intakes. No matter what size you choose. Now make a hole to you can screw the. Now normal case pressure is between 4-7 pounds, this is not really important but it is good to use it as a guideline so you don't pump in to much air when you check to see if the motor is sealed. Now that you have the intake and exhaust sealed, pump up the cases with about 6lbs of air. Now wait for at least 15 minutes and then check the pressure again. If it is still at 6lbs, then you have no leak. If it loses any air within the 15 minutes, then you have an air leak and will need to find it. The best way to find the leak is to remove anything that covers seals(side covers, flywheel and the area where the to case half's meet) then pump it back up to about 6lbs and spray with soapy water and you will find leak by looking for spots that soap bubbles are forming. Now that you have found the leak, you will need to fix it and that depends on what is leaking. If there is no leak, then my second guess would be that the gas you are using is bad, probably from sitting over time. It may also have low octane and the motor requires that higher octane fuel be used. If octane is the problem then the fix is the easiest to fix. Just by better gas like some race fuel. If your motor is not set up with that much compression, you can also get away with a 50/50 mix of regular. If you do these two tests and nothing changes, then there must be a more serious problem.
  4. I listed it for $60 OBO which means the best offer. If someone wants to offer more they can that what OR BEST OFFER means IDIOT!!!! What should I sell it to the guy for $60 when the guy offered the $65 first? Why Don't you mind you own business and read the classifieds rules like #5 & #6 or are to to stupid to read? Don't worry I already reported you for violating those rules!!
  5. I now have an offer for $65. doesn't anyone want to make a higher offer?
  6. I got an offer for $60 and unless he backs out it is his. Check this post though because I always put that they are sold when they are and if you don't see that in the next few days, the guy probably backed out. I do have to tell you that you are the second to inquire but the third person also offered $60 so if you want it you would have to pay $60.
  7. I have a brand new Accell Super High output coil that I bought for my 350 but ended up getting a whole new ignition for it. It will work with any stock ignition or any ignition system that uses a single dual output coil. The coil can be seen hear Accell Coil for $116.00 for the single coil which is what I have. It produces a spark so hot it will knock you over if you grab the plug wire and the only reason I replaced it is because I bought a MSD Ignition, otherwise I would still be using it. I did install it and made a few rides on it but for all intensive purposes, it is brand new. I would like to get $60 OBO + shipping and I am only asking for shipping because it has gone up so much lately but if it will make the sale, I will consider it.
  8. For sale a practically new set of skat-trak front smoothies size 21x7x10 for a Banshee. I bought them for my newest bike built in 2003 and it has not been run since 2005 after a bad accident. I also ran it only four times in 2004 so they have no more then 25-30 runs on them. The are in excellent shape with no leaks or missing chunks. The wheels do not look polished, but I assure you they are. The whole bike was sprayed with WD-40 for long term storage and they have not been cleaned in the picture. If you want to see them cleaned and polished, please just ask for a photo. They sell for $250 these days but I am willing to sell them for $190 OBO shipped anywhere in the lower 48. Please note the "or best offer" as the price is negotiable. I prefer Money Orders over Paypal so if you plan to pay with a MO I would be more negotiable because of the lack of any fees. I back up everything I sell with a 100% satisfaction guarantee. I will do whatever it takes to make my customers happy including a full refund, as can be seen in some of my recent Ebay transaction. The guy bought a set of tires that I said were from 1994 and worn and then he wanted his money back because they were worn. I gave him his refund, no questions asked. Please click on my Ebay feedback report in my signature to see my 100% positive report.
