drksuroo
Everything posted by drksuroo
  1. Ok so I have successfully learned how to take off the cover because I've done it four times now. I adjusted the clutch so the arrows line up. When I shifted into gear the bike lurched forward (with the clutch in) and died. Next I adjusted so the arrow was on the left side like a friend of mine and others have suggested. Still lurches and dies when shifted into gear with clutch pulled. What the heck is going on?
  2. I understand that you have to remove the whole cover to get to the clutch as in the shop manual. Is there such a thing as a case that you can remove just the small clutch cover and get to the clutch? I took off the small cover and it was solid underneath. What's the point of that? Can it be modified? (I have seen the cascade ones with the removable side cover.)
  3. I recently got my banshee and I have a question about the clutch. Whenever the bike is in gear and the engine is revved with the clutch lever pulled completely the bike still moves. I don't have any more adjustment up top near the lever. Does the clutch need to be adjusted inside? What's the best way to do this? Thanks!
  4. That's a great idea. Thanks.
  5. Yeah I saw that so I played with the rear mounts and got them alot tighter. I think it will be fine. Now if I could figure out how to make some fender mounts! Thanks to all.
  6. Here's a pic. Sorry not as clean as I like I may replace these silencers. ]
  7. I believe the mounts have been shaved and the fender brackets are gone too. I will attempt to post some pictures later today. I will probably need some add on brackets for both any suggestions?
  8. I'm new here and new to Banshees. I just got a 2001 Banshee and I need some help with the exhaust. It has FMF silencers(I think) and they have two mounting tabs. The front tabs are not attached to anything. They are close to the frame but there is no tab or place to mount them. The silencers are very loose. What do I need to mount them correctly? Thanks!
