thdog1
thdog1's Achievements
  1. Arew the headlights available?
  2. man firebanshee, your quad makes mine look like a f***ing badger! sweet ride
  3. thanks for the input guys. I used a liberal amount of pb blaster and the double nut method. got them out, I had th hammer on the rusted pins but those came out as well. You have to be extremely carful though, whenever you use a hammer on your case, use caution. I also put some heat on it via a propane torch, not sure if that helped but i got it out. thanks,thdog
  4. Hello all, I have a rusted dowel pin stuck in my upper case halve. Cant seem to get the stud out to remove the rusted pin. Is there a special tool everyone uses to remove the case studs? thanks for any input
