mr baja
Everything posted by mr baja
  1. Yep I checked and got them on the right way but I just wanted to make sure. never hurts to get a second opinion. THANKS
  2. If they were after market then wouldn't they both have a jet in each bowl? they look like factory mikuni to me and they still have the TORS on the top of them if that helps someone figure out what side to put that bowl on? (I'm lost!!!!)
  3. just checking to make sure that my bowls are on the right way the bowl with the jet in it should be on the left side carb with the choke knob. can anyone confirm that?
  4. my book only goes to 99 but is that the # off the left side of the engine case just below the carb and if it is some one with a newer book will be able to help you
  5. I have A clymer book that gives that but what is you'r serial #
  6. You can add A little more atifreeze to it and that will help a bunch. but if you want to ad some insurance to it go to A hardware store and get some heat tape put around the engine and plug it in thats pretty extreme! but you could sleep at night. LOL
  7. thanks for the help! unfortantly my new stator wires are red -white plastic covered -white cloth-red cloth-blk-and 2 yellow probably just the wrong one all together
  8. I'm sure ricks motor sport stator has different wires but if its not a problem I would take you'r info on the ricky stator an compare It to what I got. thanks
  9. Any idea on how I should wire it or will that work
  10. I have a 01 banshee and I have bought A new stator for it. but the wires don't match is this normal and if so what wires go where or did I get the wrong part? it's a rick's motor sport stator. Any help would be great.
