03300ex
03300ex's Achievements
  1. i replaces the coils, wires, caps and it runs great now, it hink i might have to try diffrent jets because it bogs a little at real high rpm's but it runs good enough to ride
  2. The tors is removed. the carbs are in sync. I switched plug wires and the left cylinder fires full time(originaly dead cylinder) and the right fire more but it isnt running at full power, i think it might be the left plug wire/cap but it is ignition problems somewere, because the left wire, when tested only fires about half as much as the right
  3. what do you meen by out of syncc? Do you mean like the tunning or throttel or jets?
  4. I had today off so i went and started messing with the carbs. I pulled them of and just kind of tinkerd with them for about a half an hour, i took them apart and sprayed them with carb cleaner, and i basicaly went through them checking for any problems. I put it back together and kicked it over a few times and got it running, but very poorly. The right cylinder was firing constantly and working fine, but the left cylinder is only firing about a 1/4 of the time to not firing at all. I think the carbs just may need a rebuild after sitting for who knows how long. Does this sound like it is still carbs or something else? ( sorry, im good with motors, but new with the banshee and 2 strokes)
  5. i got a 01 banshee for 480 bucks. it was sitting on the side of the road out front of some guys house. He told me that the motor needed to be rebuilt, and that the motor had a mild seize and very low compression on the right cylinder, he told me that it had also sat for about 2 years and that he drained the gas out of it. the quad looks in pretty good shape with some fading, but not to beat up, so i tried doing a compression test, the motor stuck 1 or 2 times but turned over, the left cylinder read about 90psi and the right cylinder didnt even make the gauge jump, it had no compression, wich at the time amased me. So, anyways i ripped it down and got the motor out. i pulled the head off to find only one piston in the left cylinder. and the right was gone aong with 95 % of the rod. Witch ment that the motor was previously taken apart. to sum things up i tore the motr down to nothing and replaced the crank, and pistons and rebuilt with .20 over wisecos. i put it back together and i have fuel, spark, and about 125 psi of compression in each cylinder. But when i kick it over all i get is a few pings of the right cylinder and it wont run. i cant figure it out? any ideas?
