dbt350
    2006 white w/ silver, FMF Gnarly exhaust w/ FMF Turbine Core 2 silencers.
dbt350's Achievements
  1. Well I hopped on it today and the bog has gotten worse. It was bogging about 1/4 throttle, now it does that plus when you get on it full throttle. It does ok at about 3/4 throttle. It didn't do that until I put the filter on it.
  2. I have a stock 06 banshee. I just put a FMF Gnarly exhaust system on it. It started bogging when I wasn't getting into it hard. Then it fouled the left cylinder plug. I put a Toomey air-filter and prefilter (no air box) on it. I was wondering if anyone knew what kind of jetting I need to do. I am in North Carolina(35 degrees at lowest) and sea level, maybe a little above. Thanks
  3. Hey man just wondering if you could help me out too. I got a 06 with FMF Gnarly exhaust w/ turbine core 2 silencers. It was bogging down and then fouled the left cylinder plug. I changed plugs and put a toomey air filter and outerwear (no air box) on it. It runs good but wants too bog when you are not getting into it hard. I got the whole system with a jet kit that came from washington state and I am in North Carolina. I am not sure if that jetting will work here (sea level, maybe a little above, 32 degrees at lowest). I've got to find out the exact specs on the jet kit but just from that info do you have any suggestions of what I need to run as far as jets and is that the reason it is bogging? Thanks
