this is the problem that i am having, the bike starts fine and revs fine, when you put it in gear and put a load on it. it stops running off the right hand side. carbs were completely takin apart and cleaned. a new stator was put in. the coil was swapped the c.d.i box was swapped the pipes were checked for flow. put new cylinders and pistons on it. compression is good. and leak down test is good and it still wont work right. right now its with a guy who works on banshees only and even he cant figure it out. so any advice would be great. thanks.....Could it be in the wiring harness.
