C.J.
    01 +4 stroker...
C.J.'s Achievements
  1. ok... i just regained interest in my shee. it has sat for 2 years, and i forgot a few things... i built a 4mil longrod and parked it. .060 bore, rec/drag port for stroke, v3 reeds, t5 pipes, coolhead w 20 or 22cc cut domes, pro design pro flo intake, twin 35mm keihn air striker carbs... where i live the elevation is about 1350' it does run, but i don't wanna take it anywhere until the jetting is close... any advice on some ballpark jets? id hate to pop the new motor due to stupidity... i run 93 pump gas, 32:1 klotz r50 and b7es plugs... any advice is much appreciated and thanks so much in advance!!!
  2. C.J.
    WANTED: 4mil domes
    any help?????
  3. C.J.
    WANTED: 4mil domes
    i'm in need of cut cool head domes for a 4mil crank. preferably 20cc's..... live in pa.... i have pay pal.... any help???? thanks!
  4. what intake setup are you running??
  5. is it adjusted correctly?
  6. thanks to all... hopefully reed spacers will cure the problem!!! hate to lose out on my perty intake
  7. thanks to all... hopefully reed spacers will cure the problem!!! hate to lose out on my perty intake
  8. would anyone be so kind to point me in the right direction... how do i go about modding the float bowl to clear the clutch arm? any kits available? different bowls? different acess plug? intake? would reed spacers help? i currently have /would like to run a pro design pro flow intake for 35mm... i'd appreciate some input....
