BANSHEEE
Everything posted by BANSHEEE
  1. Yes the carbs are synced.
  2. Taking of fast and slow justs boggs real bad feals like you have to load it up and then power band comes on.
  3. How do i stop the boggin down low.Also tryed the needle at the top still the same.
  4. Just did a top end rebuild a few weeks ago bike has fmf fatty pipes,tors removed dyno jet jet kit 290 in the main. Bike idles really nice neddles are both set in the middle and i tryed 2 and a half out and also tryed 1 and a half out on the air screw bike still boogs down low and power band kicks in really nice.Pro lites piston 4 over are installed. thanks for any help.
  5. Bronx just moved to Westchester
  6. Bronx
  7. Thanks for the info guys i'll start with the needle in the middle and i'll take it from there See what happens. Thanks again
  8. Just need a good starting point for the following set up + 30 on the pistons,modified air lid +4 on the timing,fmf fatty exhaust,Dynojet jet kit with 280 on the main and the clip is at the top of the pin and 2 and a half turn on the air screw followed the instructions on the dyno jet kit.Bike idles nice carbs are synced.Bike bogs outs at low rpm 1/8 to 1/4 feals like you have to load up the carbs to move. Stock Carbs
  9. Finally got the banshee going found a broken wire in the harness that was used for the key.Heat shrunk the ends and repaired the ground wire by the cdi bike idles smooth and starts right up. thanks again
  10. Didn't get a chance to look at the SHee today but did order the Toomey Thumb Throttle Kit to get rid of the TORS will update soon. Thanks for the helpful information
  11. No Paint i will go back at it after work tomorrow with a meter again and disconect the tors and go from there. With the tors hooked up and WOT no spark but i will still disconect it and go from there.By any chance do u guy think it has something to do with the carbs/throttle cable. ::
  12. Just did a top end rebuild +3 prolites bike started ran fine synced the carbs everything was nice shut the bike off wont start.Replaced stator,coil,pickup sensor,plugs,cdi,and still bike gets one spark and won't start.Checked for grounds loosewire/broken wires every thing looks good and ohmed out good.key is removed and bike still has tors. thanks for any help.
