Hey guys, I've been reading a lot on here trying to deteremine what is wrong with my shee. I don't even know for sure what year it is, I bought if off someone who I think was a bit shady, it's got parts from every year on it. For discussions sake, I believe its about a 91. Either way just about everything is aftermarket. Here is a list:
Keihin carbs PWK
K&N filter
FMF pipes
New stator/flywheel (as of last summer)
New ignition coil (as of two days ago)
I rebuilt the motor again, after a screw on the clutch side popped out and found its way between the main drive gear and driven gear. Broke a whole tooth off my main drive gear. Due to that it bent the crank. I've gone through and replaced the crank, new drive gear, and primary clutch gear. Got everything back together and it just will not start. Went through the carbs 3 times, being absolutely sure everything is good. This thing ran like a raped ape before all this happened, everything is dialed in.
Plugs fire a blue spark outside the case, but I always wonder what's happening under pressure, and in the presence of fuel and the like.
The plugs are wet, so I know it's getting fuel. The only thing on the whole bike that isn't new, as of last summer, is the CDI.
I've read those things almost never go bad, I've also read that some have gotten an out of box failure CDI. Again, it sparks so I don't know if it's possible that the CDI is bad. Is that possible?
Also, when I try to start it, it seems like it wants to but only when I pin the throttle open about 3/4. It's popping like it wants to but just won't.
Sorry for the long winded responce, just a little frustrated. If anyone lives near brighton, MI and has a cdi they'd be willing to let me try before I buy one, I could swing over with a case of beer. I have the older style. Style A from this gentlemans posting:
http://cgi.ebay.com/ebaymotors/NEW-YAMAHA-...sQ5fAccessories
