Fatal Venom
Fatal Venom's Achievements
  1. Looking for a nice set of tires and wheels for my 01 shee. Not really looking for paddles but will take for the right price. Please include the price for shipping also. Thanks guys!
  2. I figured it out guys. It was the aftermarket timing plate and pick up coil. I moved the pickup coil and it revs just fine now. The gap was in spec but i moved it closer and that fixed it. Thanks for all the help!
  3. The choke tube is hooked up. I will check the compression tomorrow but it starts on the first kick and will sit there and idle but if you try to give it gas it just boggs. I will post up tomorrow. Thanks for the responses guys!
  4. Any ideas fellas? All the tors are removed, no emergency brake. Starts first kick and idles but has no throttle response. I have changed the complete wiring harness, stator, coil, cdi box and cleaned the ground. I have an aftermarket cdi box on it now, so can this be the problem? It has a bright blue spark also. Thanks for any help.
  5. Im new to this banshee thing but there isn't a emergency brake anymore. TORS are totally gone except the wiring plugs. There is quite a few plug-ins that i don't know where they go or don't have anything to go to. There is no key switch and the kill/headlight switch isn't hooked up either. Im not sure how to hook up the handle bar kill switch too.
  6. Hi guys. I just bought a 87 banshee as a project and need some help. Basic rundown off the bike, fmf pipes, tors removed, air box removed, 97 stock bore motor with .30 thousands shaved head. When i bought the bike it would start and run fine until it got hot and it wouldn't start again unless it was pop started. I got it home and it wouldn't start at all, checked the spark and there was none. The wiring harness was all chopped up so i bought a new harness, stator, and cdi box. I put everything on the bike and it starts first kick but won't stay running and it has no throttle response. Any suggestions and help is greatly appreciated. Thanks!
  7. pics to [email protected]. Please send paypal info too. Thanks
