HELP.
I just rebuilt my banshee last week. It started up with 2 kicks but noticed left side cyl will was not firing.
So i started troubleshooting the easiest first.
New plugs that are gapped, switched around plug wires, switched around carbs, and still left wont fire.
Took readings with ohmmeter, stator is good, preformed the primary coil test wich also checked out.
Next i was told to start it up and put my hand over the left side carb and feel for suction, which there is. So im pretty sure the motor is sealed up tight.
When I pull the plugs left is soaking wet and right plug isnt far behind, I havent messed with the jetting since it ran last.
My compression is up to 165 psi on both sides. I havent preformed a crankshaft pressure test but if both carbs are sucking air ........ then there should be no leak... right???
Any help will be greatly appericated.
