maxb750
Everything posted by maxb750
  1. hey guys, I have a complete set of banshee arms (4). How much are they worth seperately or together.....a good worth price that is...??... thanks, they're from an 02. Max
  2. i'll check out the carbs....thanks, max
  3. Hey guys, I have an 02 Shee with the carb kit(no tors). It only dies if i try and idle for a while but stays alive with a bit of throttle. It runs perfectly thru all rpm's so i'm thinking its the idle adjustment. Each carb has a brass screw to adjust, correct?? Turn them both in(clockwise) to increase the idle...correct?? The carb on the left won't turn any more clockwise and I haven't really messed with the right one........any advice is appreciated....thanks, Max It hasn't been run for a few months and may be loaded up....could this be the problem and maybe it just needs to be run a bit??
  4. i got one...thanks guys, Max
  5. as stated, I need the stock thumb throttle assembly for my 02 banshee....no cable needed. Let me know if you have one, thanks, Max
  6. that's strange.....ok, another pm sent. If you receive nothing then my email is [email protected] . thanks, Max
  7. pm sent
  8. Anyone have one for sale?? thanks, Max
  9. As the description says.....i need the tors cable to go into my CR style twist throttle. Anyone have one?? thanks, Max
  10. NYUK....pm sent
  11. I may take you up on it......i'll pm you if i can't find one locally, thanks, Max
  12. no...not that one....the one the CABLE goes thru. You can adjust the freeplay of the throttle lever iwth it. Got one?? Max
  13. Hey guys, I need the throttle adjusting screw that goes into the throttle housing on the handlebars that the cable goes thru.....does anyone have one. I believe its a 14mm thread.....i think. thanks, Max
  14. thanks.....do these bikes go out of adjustments quite fequently because of the shakiness of the two stroke??
  15. in or out for a higher idle??
  16. thanks for the help, I think the TORS is removed......when i bought it the guy told me it had a Carb kit installed. There is no body of anything above the carbs, just the silver lines going into the tops......on each side of the carbs are large brass screws which I thought were the idle adjustment screws...am i right?? thanks for your help, Max
  17. Hey guys, I'm new to the banshee world and I have a couple questions. The Banshee I just bought(02) starts on the first kick and runs great....but it dies a few secpmds after i let off the throttle.....but i've noticed it only does this when its cold or sitting for a while in idle. Are these bikes cold blooded?? and are they capable of idling for more than a minute or so?? and how do you adjust the idle as I think this would take care of it as it seems to me to idle real low.......thanks for any advice!!!! Max
  18. well...i don't want to lowball you but how does 25 shipped sound?? let me know how much you want for it it the offer is no good. thaniks for the reply, Max
  19. hey guys, new here to the banshee world and the forum.....i need a stock front bumper for my 02 banshee. Anyone have one for cheap?? I have Paypal ..... thanks, Max
