I have a 91 shee that has
just over 5 hours on rebuild
Toomey t5
bored 30 over
new wisco piston set
hot rod crank
upgraded rev box
Ricky Stator, flywheel, stator and timing plate "I belive"
Billet alum. reed cages
boyesen power reeds
wire harness cut to racing specs
ok i have no power band i was told that the key for the fly wheel was wrong when i bought it " 2 days ago" so i bought a stock key i was also told the jetting is probably off it has a 270 main 28 pilot and im not sure what the needle is set at what should i start with as far as setting timing plate, what jets and what to set the needle at thank you
