billybob1
About billybob1
  • Birthday 01/31/1969
Contact Methods
  • Website URL
    http://
billybob1's Achievements
  1. i got a set of 2005 stockers brand new let me no
  2. i have a set of 2005 stockers still brand spanking new let me no
  3. i got 1 brand spanking new 2005 15 minutes ride time period 150 shipped let me no
  4. billybob1
    10 inch rims
    i have a pair already polished for the same price there just nicer let me no
  5. i have a set of brand spanking new stock front to back both sides for sale 100 u pay ship, let me no
  6. yes crank seal was put in new less 1 hour ride time i did notice i have oil over flilled quiet a bit,, i have big bore kit it"s all the way out with wiesco stroker +4 or 5 i don"t remember for sure mm long rod kit, ported chambers but i do not no anything about the carbs the shop did all the work in fayetteville ARK!
  7. billybob1
    swing arm
    like i said i got one
  8. billybob1
    swing arm
    i got a stock one with extended axle bolted too it and brake w/hubs and sprocket
  9. i got it let me no
  10. do u have to use gasket sealer on head and jugs when putting the head back on your banshee? Do u have to use brand new gasket or is the old one ok to reuse , there were no proplems so i want to reuse gasket it is 2 part do to the spacer plate between the 2 gaskets for the stroker crank installed , so it isn"t a cheap one i"m sure looks like it"s in great shape though ,,,,thank u?
  11. any help with the last questions ? anyone plz?
  12. ok i didn"t really get a good smell the neibor guys walked over to ask if i had it fixed yet and i was trying not to let him see this smoke still coming out of my tailpipe and the bike was shut down lol as i said yes i think i finnaly figured it out how hard is it it change the tranny seal and where is it located? well oviously in the trans but u no, through the side cases or what? and why would it blow one ??? Also last question how do i sync the carbs cause yes i have messed with the cable length ajusters on the tops to try to get them the same amount of opening then locked them down tight, never turn a screw on them or nothing, and as for reeds i have never change them , but i have had to leave the air box lid off or the bikes won"t rev up like it had tors system on it or something, my old air box cover has hole saw sized holes drilled out of it i guess i"ll put that 1 back on see what it doe"s do the the situation, only other thing doe"n to it was i put all 2005 electronic front to back in cluding coil on the 1993 shee?? anymore ideas or tips or tricks to syncing the carbs?? thank u
  13. yes the plate doe"s go between the jugs and the head i took it off there thank you omg! it is what gives u the height cleanace for long rod stroker crank lol! with out drilling the domes hire in the head! HEHE any way what ways do i notice crank seal going out and what made it do it there brand new less 1 hour ride time on this motor rebuild! also should i be able to ever so slightly move piston side to side when it is still in it"s cyclinder?
  14. it only smell like heavy burnt oil maybe i didn"t really notice to tell u the truth, and yes the plate goes on top of jugs,,,not both,, what do i check tranny oil for , gas water ect there was nothing in it, out of the ordinary, i did just change engine oil though right before i rode it come to think of it could i have over filled it maybe?
  15. it seem bike was over heating do to water pump being out , i have head off just to check head gasket to before sure, head gasket looks fine and never was burning any antifreeze to begin with but buddy told me to check it cause that was the first idea he had when it started spitting coolant out of over flow on the resivor tank, promblem was fixed i guess with new water pump , but last time i took it on the trial ride after change i shut it off and hadn"t had any coolant hit me in the face was nice but right bank or tail pipe continued to smoke heavy for like a whole 1 minutes time never had seen that before ever,dark smoke so i took my blower tip from the compresser and blow some air up the tailpipe and here came a bunch more smoke a couple 3 times i did this, could i have scorched the rings in the 2 rides i rode it for about 3 minutes untill coolant hit in the face inother words overheated? i have the head off now what should i be looking for as far as piston play side to side in the cyclinder , jugs still on bike of coarse,,,it moves left to right less then a 16th as far as piston slop i guess for lack of a better word rings bore and all have less then 1 hour total ride time on them, but just wondering, no signs of head gasket leaking but have 3 part gasket setup , do to the spacer plate between the two head gaskets for the stroker kit installed, any ideas guys?????
