i got pictures and my e-mail adress is [email protected] put banshee in suject line i will send pictures asap to all return e-mail adresses with banshee or banshee motor in subject line thank you
i retorqued the head bolts to 20 ft pounds and in proper scquence aswell, they all turned at least well how should i say this ,,,,on a 5 sided nut they all turned atleast to the where the next side would be so a 5th of a turn atleast !
also why would i re jet the bike and or change spark plugs all i relly need to do is figure out this coolant problem bike runs great , the old air box cover had 2 inch holesaw holes in it to get it to run so no cover just filter will be ok won"t it?????
well i use 10w30 motor oil not any kind of gear oil in my bike that i no of, but what i ment was can"t i do a compression check to see if head gasket is leaking before spending lots of $$$
i don"t think it it a coolhead ort ect , if headgasket is blown what is the easiest way to tell , or if water pump how can i spend the least amount of money and no for sure any ideas on going this route i will go check head bolt torque right now before i post again on the ok ! thank you for your patience
also i did take w pump inspection cover off and looked at the impeller it looked all good but seemed have maybeen rubbing or spinning against the cover it"s self cause there was a round circular scrapping on the meddal cover it"s self from the plastic impeller , also kicked the bike over with cover off and it turned
i have never had it off only the engine machine shop , and yahama junior racing team has worked on or even seen if fayetteville ARK so i guess i need to take it off
yes i does appear to smoke alittle more then it did but i had just changed to synth benoil and 110 octane fuel for the first time , but these changings were after the fact
what about water pump seal cause head gasket r new less 1 hour since total rebuid was done , plus what would make me blow a head gasket?
also all electronic used on the 1993 banshee r now powered buy the 2006 shee coil voltage reg. ect would i be getting any different kind of spark or timming may be out now?????
what other symtoms did u have only asking cauase i want to be shure , what makes u blow a head gasket ?
i only rode this bike for an hour or so since i had it rebuilt the engine that is and head gaskets were brand new then
i recently changed almost all parts from a 2005 onto my old 93 shee cause i had the motor stroked ect, and anyways long story short the radiator whit cap removed is not staying full, plus it"s blowing the rubber stopper of a cap of my over flow tank under the seat and plastic causing anti freeze to drip onto my rear disk , also noticing that uparound my fuel tank lid is getting antifreeze very slightly blow onto it and tank plastic after riding it for lets say just 5 minutes or so any Idea"s anyone , do i have the hoses to the overflow resivor backward possibly , one of the hoses going back there have a tee in the middle looking like it would be water pump bypass outlet should that hose be the top or the bottom hose going into the overflow resavor???? THANK YOU FOR ANY HELP [email protected]
