bucknaked
Everything posted by bucknaked
  1. i figured i needed a compression tester that is a no brainer I was wondering what numbers i should be looking for good compression how high should the tester read or should i just be concerned with cylinder leak down i believe it is still stock bore my banshee will not start unless i spray staring fluid around the air filter i was wondering if i it needed the top end rebuilt seems to run fine with lots of power after it has started it just will not start with out the starting fluid may be it is the carbs i am just trying to figure it out any help thanks much also how much should a top end rebuild cost
  2. Hi 5150 thanks i tried that but could not navigate to were i wanted on the site could not find any 1999 models went to history that was pretty cool
  3. Is there a way to check compression on my 1999 banshee if so what is the correct way to do it what should the compression be thanks much
  4. Any one no a good site to see a lineup of 1999 banshees stock photos i was wondering how many color options there were for 99 thanks love the bansheeHQ :biggrin:
