sandman643cc
Everything posted by sandman643cc
  1. ya a friend of mine chromed his flywheel and back lit it with LEDs. Pretty sick looking!
  2. thanks sandrider! I forgot to mention that I was running tailight as well. I will make some connections and see what comes of it. I will let everyone no how it turns out.
  3. hilareous. Thanks for the reply, there are 2 yellow wires going to the plug, one goes to the stock lights so I believe you are speaking of the other yellow wire. Also will I ground the other wire coming from lights? and the teather kill I can connect one wire to ground and one wire to the black/white wire. there is one wire left and that's the blue wire should I connect that to anything or just wire nut the end?
  4. ok, it is a normally open switch.
  5. I guess I'm not sure what you mean of open or closed
  6. Hello All! I recently purchased trail tech headlights and a pro design kill switch. My plan is to eliminate the stock on/off switch but still want to run lights on occasion. 3 questions.... What wires do I tap into on the harness for the lights so they are Always ON? ( I will make quick connects for when I run lights) there is 2 wires on lights which wire is what or does it matter? 2 what wires do I tap into ( on harness not coil) so the kill switch functions properly? I have viewed the wiring diagram and think I might no what wires to use but am second guessing myself and am just unsure. my bike is a 2000 and the wires I have to choose from are: black/white stripe, blue, black, yellow. sorry my pictures may not load, but thanks in advance for everyones help!!!!
