jimbo
    2000 banshee
jimbo's Achievements
  1. :biggrin: Thanks for the post. Mine started running on one cylinder, firing and mis-firing. I swapped wires like you guys say and the cylinder fired right up. Turnrd out to be the cap on the spark plug wire not seating properly. Thanks again !!!
  2. thanks, the fuel is coming from the bottom nipples so i'm guessing the drain screws are not seated all the way in so i'll try and tighten them. Thanks again
  3. Just purchased a 2000 Banshee Wednesday and i'm not familiar with it to much. When the bike sits over night, there's gas leaking and i think it's coming from the two nipples at the bottom of the carb. bowls. Are those nipples for the bowl drain or are those nipples suppose to be connected to each other by a hose? there's another hose about midway on the carb that's about 3 inches long on each carb. Are they the drain hoses or are they suppose to connect each carb? thanks jim
