rhino12
rhino12's Achievements
  1. I will double ck. on all the jets just to make sure. It fouls that plug after 2hrs. of riding or so. Not sure how strong the spark is on that side. I'll ck. on that. If it is out of syn. won't it run poorly all the time? Thanks for the help!
  2. Both jets are the same and air screws are the same. I am running yama-lube at 32-1.
  3. Help! I have a stock(except for a twin air filter) 01 that keeps on fouling the left plug. It will reeve up and then quit. After putting new plugs in it still does not want to start up right away. Once it is started then you can turn it off and start it right up. I have allready cleaned the carbs and all the carb settings are stock. Any ideas??
