So...I changed the carb back to the stock carb and it will idle now. When I try to rev it, it's doing the same thing...making that bogging sound. It seems like it's starving for fuel, but it's not.
I had a question with regard to the stator. I have checked all the wiring and that looks fine, although when I check the lighting coil resistance and it was zero. There's no continuity. I also checked the pick-up coil resistance and it was 148 (out of range according to the manual). The charging coil resistance was 18 (which is on spec according to the manual).
The flywheel for the stator looks to be okay. There are no cracks and it doesn't look fatigued at all to the naked eye.
If I buy a new stator, do I need to also buy a new flyweel? Is the stator what is causing the problems with the Banshee not being able to rev?
I tried to test the ignition coil, but my ohm meter does not read RX-1. What is the best way to check to see if the coil is functioning?
I also did a spark test and the spark was a little weak.
Some more background: I was riding over in Dove Springs (CA) and the Banshee suddendly died. I was trying to gas it and then it started to make the same bogging sound as it is making now. Once I took the motor apart, I found that the right cylinder had seized. So, I ended up changing everything and had the cylinder bored to 65mm. Not sure if this incident (the bogging) is realated, but thought I'd give you guys some more background to work off of.
