I have a Yamaha Banshee 350 to 409 Complete Big Bore Kit. This kit produces plenty of horsepower while maintaining engine reliability. These Cylinders have been resleeved by LA Sleeve with new Big Bore Sleeves, then bored and honed to matched the cylinders to fit the coated Big Bore pistons. You get 2 Resleeved Cylinders, 2 68 mm Pistons, 2 piston pins, 2 piston ringsets, 4 pistons circlip and a top end gasket set-ready to instal-no crankcase modifications neededl!!. Works with a stock stroke crank. All is new never used (the out side of the cylinders are used). Retail is $825 plus shipping your Cylinders both ways total of $875. These are ready to install on your engine. The sleaves have already been installed into a set of cylinders. I have them in my hands ready to ship. $780
Also I have an LA Sleeve Heavy Duty Hot Rods (not a cheap no name) direct replacement crankshaft. The webs were the only thing that had been run. This crank will drop right into the factory cases without any machine work or even aftermarket pistons. This crank is trued, Heavy Duty new Hotrods and Pins installed, all new bearings and seals for crank and rodends are included. It is stock stroke. These cranks are much stronger than stock, and will take the grunt of the higher horsepower engines. This crank has not been installed or ran since LA Sleeve sent it to me. I had it built for a 409 kit I was going to run. $420
I will pay shipping on either or both. I can do a buy it now on ebay if you like.
Wrench
