dakota-man
Everything posted by dakota-man
  1. what do dealers put in thare? all i need is a baseik dealer lube! im going to sell this thing. I have no interest in raceing or performance.
  2. should i just run the senthetick stuff or what? and the oil I pulled out didn't have a smell at all
  3. what oil should i use? i cant find it in the manuel
  4. I got this thing cheap! its been melted down, had no clutch, and no tires. well when i decided to look in to the clutch I took off the tran cover and the oil that came out looked like 90 weight, and made all the clutch disks stick together. the friction disks are good and thare are no heat scores on the plates SO I was wondering whether to clean or replace the clutch disks? and what oil to add when i get the dang thing together!
  5. THANKS A TON i'd never get this dam thing running with out you guys thanks :beer:
  6. I need to know if a stock 2005 banshee flyweel will fit on my 1997 banshee? i had my brother take it a part and he tried to us a 2 arm puller and bent it. :: thanks
  7. Are the sleeves of a factory sleeve coated withanything special that makes them harder? or not
  8. we just finally t have taken our new/ used not running banshee eng apart, the pistons are melted to the rings by the ex port side. Now my dad has a boring tool and we need to know how much can be taken with out being too thin, we see there are piston kits up to .100" and the one sleeve is rough shape dad also needs to know what the stock bore is thank you
  9. nks for the information, we will check out the compression and I see we can order the [tor] coversion kit. and we will most likly be back for information thanks again and have a great holiday
  10. hi i have a problem. i dont understand. when i try to start it it wont fire and when it dose fire it only coughs out the exaust. it originaly didn't fire but i cleaned the staters up and that is solved. thanks :thumbsup:
