duner276
    2000 neon orange and white ,holeshot built 350,t-5s,coolhead 19cc domes,28mm pwks bored to 30mm,VF3s,pro design intakes,toomey clutch ,tons of chrome and powder ,cascade billet and vinyl ,+6 swinger ,eibach rear spring w/revalved shock ,haulers and smooth buffs
duner276's Achievements
  1. yes ,just make sure you do not get a 40mm carrier ,those are for drag axles,when you order it just tell them it will be for a stock axle,i think they are 35mm.
  2. how much exactly needs to be removed from lower yfz 450 a arms to fit?i am trying to do the swap but i all i can find are pics no measurements.do i cut all the way up to the welds?
  3. those look exactly like the magnum a arms on my wifes banshee,i have been told that they are just automotive ball joints , i would take one to a good auto parts store,if nothing else they would probably have the boot.or look in dirt wheels for a place that sells magnum a-arms
  4. i have tried just about everthing,swapped out carbs ,cdi , coil , this engine is new to me ,but the old one did the same thing that is why i am pretty sure it is electrical and i have ruled out stator problems since it is a completely different engine. it just misfires and runs like crap at lower rpms then goes away and runs pretty good.yes,both engines same symptoms . i am new to this website.any help would be greatly appreciated. could it possibly be the on/off switch or wiring harness ?this is all i can think of that has not been switched. i am getting very frustrated i have spent hours reading other posts on here to get ideas .thanks
