cuddie 1
cuddie 1's Achievements
  1. It did it before I installed the filter. Do you think it is fuel and not electrical???
  2. Hey I have a 87 Banshee it has T-5's K&N filters in the stock air box with no lid, twist throttle, key switch removed other than that its stock. When I am ridding or just running it in the garage it will start to die out and at wide open throttle it just bairley stays running and will not rpm up at all if you shake the bike a couple of times it will stop and run great. I have a clear fuel filter on it and when it does it the filter is always full. The bike has never even fouled a plug??? Help! Do you think this is a fuel problem or possibly electrical???? When the key switch and the tors were removed the plug ins are just hanging there could this do it??? The guy I bought it from put a new stator in it to cure the problem but that obviously wasn't it. Pick-up gap maybe??? I am ready to blow it up HELP ::
  3. Wouldn't it have to effect both carbs in order for the bike not to rpm at all? What are the chances that it effects both carbs at the exact time?????
  4. Yes the bike runs bitchin' this problem is intermitant and seems to really do it more when it is hot. Sometimes the bike has to be push started???? Electrical? Wiring?
  5. Hey I have a 87 Banshee it has T-5's K&N filters in the stock air box with no lid, twist throttle, key switch removed other than that its stock. When I am ridding or just running it in the garage it will start to die out and at wide open throttle it just bairley stays running and will not rpm up at all if you shake the bike a couple of times it will stop and run great. I have a clear fuel filter on it and when it does it the filter is always full. The bike has never even fouled a plug??? Help!
  6. Hey I have a 87 Banshee it has T-5's K&N filters in the stock air box with no lid, twist throttle, key switch removed other than that its stock. When I am ridding or just running it in the garage it will start to die out and at wide open throttle it just bairley stays running and will not rpm up at all if you shake the bike a couple of times it will stop and run great. I have a clear fuel filter on it and when it does it the filter is always full. The bike has never even fouled a plug??? Help! ::
