06specialbanshee
Everything posted by 06specialbanshee
  1. sry thats my bad i live in PA and the elevation aroung my area is 2000-2500 ft. i tried so many diff variations with those carbs bet i had them off and tore apart 100 times if not more. people tell me that thats how the banshees are with the bottom end bog but i rode them b/f and this isn't running right at all.. its like when you just punch the throttle on a low end bog the motor just burrrrrrrrrrrrrrrrrrrrrrrrrrssss alomst like a bbuuuuuuuuurrrrrrrrrrrrrrrrrrrrrrrrrrrrr its HAHAA its hard to explain then as it starts to pick up R's it eventually with kick in and take off.. but sometimes its bogging so bad it won't come back even with the slip of the clutch. see i'm a big hilll climber and when i am climbing hills with is it just dies and we though it might be the floats but we adjusted them and there good now.. cause when i would pull my air box lid off with i have holes cut in the air box would be full of gas. i'm tryin to explain this as good as i can i just wish sum1 who actually knows banshees really well could just be here to see what i mean.. again thanx guys for the help
  2. Hey whats up guys well i just bought a 06 yellow special addition banshee and threw a bunch of mods on it. I just put toomey t-6 pipes on it, v force 3 reeds, reed spacers, carb rev eliminator kit on stock carbs, k&n air filter kit, and i have a 400 main jet in it right now and a 27.5 pilot. The plug is burning perfect but the quad on bottom end just seems like when its running it the choke on. when it opens up though it rips. i was going to flow port and polish the head, shave them and throw some different pistons in to see if that will do anything. Alot of people told me you have to have a little motor work done not just bolt ons to really make the t-6's open up, they are ALOT fatter than the t-5s and i was thinkin that i need some more compressiion to make the pipes work.. its almost like the pipes are bogging the motor. and theres no way i should be up to a 400 main either people said. i don't no whats wrong with it i know thats its not running right. any suggestions would be much appriciated. thanx again..
