After you got your cylinders bored and honed did you make sure your ports were chamfered so your piston rings wouldn`t snag on the ports? If they weren`t it could have bent or cracked your fresh rings. Sometimes a compression test won`t show a bent ring problem. So you will need to do a leakdown test or remove the head and cylinder to check.
