sLo-DsM
Everything posted by sLo-DsM
  1. 1800 takes it 1900 with the hjc helmat like new conditon
  2. Anyoe ??? make offer
  3. Bump.... 3,200 in Martinsburg , WV 25401 runs great starts on 1st or 2nd kick almost always
  4. I have a 99 Banshee it had a good bit of work done on 6/29/06 it had piston kit 64.50mm,top end gasket,top end bearings, coolhead o-ring kit, plugs and gear saver. its board .50 over has a coolhead, boost bottle, boysen reed valves, DG nerf bars, DG Front Bumper, FMF pipes and fmf power core silancers,Full skid plates under a-arms frame sproket ect (shown in pic) it has a new sticker pack carbon fiber look .i am askin 3400 OBO or trade for a srt-4 crashed with good engine and wiring This quad is very fast i live in town and dont have anywhere to ride it and dont have the time with my 5am to 7pm 5 day work schedule. i have had it out twice since i have had it. i got it in july/06 about a month after all the work was done on it i rode trails when i did ride it there wasnt any hard riding on it since i got it the owner before me also said he only rode trails. the plastic is not shaved all stock plastic in pretty good shape few scratches from trail riding twiggs and stuff
  5. I was reading one of these posts and it said that if you take the tors systen off the shee wont idel right and will shut off when ideling is this true? also the wires by the kick starter that are spliced togeather are those also for the tors sys if so could i cut them behind the connector where there are only 2wires then after the connector they turn to 4? thanksthanks alot
  6. Well i was messing with it a lil bit a ago and i took the rubber from around the e-brake and the brake line was broke and the part of it that you have to move to engage the brake was ZIP TIED to the set postin so i took the wires off the side and there wasnt any connectors inside just loose wires. I turnd the fuel off and kicked it a few times in case it was flooded turn the fuel on kicked it and it tried to start kicked it again and started right up then i let it run for a few mins and it was fine turned it off and started it with no choke and givin it no gas on the 1st kick so i geuss it was sumting in the e-brake switch also there is a little white connector beside the coil that is unhooked and there are two silver boxes under the seat looks like there hooked to the intake sys or carb that have a yellow and a black wire on each of them both (all 4 wires) are cut? and there is also 2 wires zip tied to the frame 2 sets of black and yellow wires hooked into each other (4 wires all togeather 2 black 2 yellow they have one black hooked to one yellow making it into 2 wires ) this is a 99 banshee any help or links for removal of the tors box i think it was called what needs spliced togeather ect also where was the igniton on these at so i can check to make sure they are connected good and not coming lose cuasing this problem. Also with the Tors box removed will it still idel good ? thanks guys for all the help
  7. im not sure what the dome size is due to all the work being done prior to me buying it (should have got a stcok one and did work myself) the stuff on the recipts is all i know of being done to the motor. when i rode it it started on about the 3rd kick and after warm it would start on 1st kick with out any throttle or choke just start and idel it ran very good and that was about 4 or 5 days ago now.
  8. i do shut it off whe i can remember i went out there a little bit ago and ther was a larged sized pudel of fuel under the atv looks like it ran out from one of the orage colored lines that go into the carb
  9. Check it with a regular automotive compression tester? what should the compression be at? if it is low compression what are some of the causes? it isnt very hard to kick so i geuss it could very possibly be compression. thanks for the help Edit* I for got to say i have all recipts for work done it was done 6/29/06 it included the following piston kit 64.50mm top end gasket top end bearings coolhead o-ring kit and new plugs
  10. its a 99 and it hasnt been sitting long at all i rode it then 3 days later it wont start. i will try starter fluid does it have to be napa ? alo some time(not all the time) when i try to kick it with the clutch in it will move forwards a little bit ? i would also be thankful for help with that Chris Edit* i Forgot to say i did try to drift start it and it did the same thing with the ligt coming on ect..
  11. Hello i am new here i just got a banshee a few days ago i went out riding and it was fun ran really good no problems. I broght it back to my garage it sat for 3 days i went out to start it and it will not start i repalced the spark plugs and still wont do anything . I got the atv as it is its Board .50 over, cool head, boost bottle, boysen (or sumting like that ) valve reeds, there is not a key on this wasnt when i got it i am very good with cars but have no experiance on atv's and it being 2stoke it a whole new thing to me. ill kick it for 15-20 mins and it will not start it acts like somthing electrical but im not sure. what i should check im not sure where anything is located at on these. it trys to start the headlights come on but it acts as if i am drift starting it with the switch on off just sound like it wants to start but bogs down lights will light up for just a second then nothing after that. Thanks for any help
