bobdawson350
    1998 Banshee yellow/black 350 fmf fattys,power core 2 silencers, 280mains, boost bottle, turned out wheels! k+n with no airbox lid. duncan reeds.
bobdawson350's Achievements
  1. cheers for the replies guys as i said ive already stripped it all down and the shift forks all look fine ive had them all totaly to bits. but i suppose it would be worth checking the adjustment on the shifter again. coz its only taking the side casing of! cheers again bob. do you think it would be worth investing in one of those uprated shift stars?! cheers bob
  2. hi guys im new here but i was hoping you could help me with a problem iv gt!! im having problems shifting from 3rd to 4th using my shee on an mx track but it usualy just doesnt go into 4th. but when draging and shifting up it either doesnt change up, or the gear box gets jammed up and im only able to get two gears usualy 3rd/4th presumably because its under more load! when not going that last 10% gearbox feels realy smooth! any ideas on what could be causing this?! ive already had the gearbox apart and everything looked in fine working order! no chipped teeth or anything like that. all i replaced was the retun spring on the shifter and the bearing for the selector drum. i thort id solved it but it happened again this weekend! cheers bob.
