I got my Banshee put back together today and when I was tightening the cylinder bolts down one of them pulled right out of the case. It pulled the Time-sert right out, now it only unscrews it if i tigten it more. The other 3 tightened down to the specs in my Clymer Manual. Will 3 bolts hold a 68mm bore and 4mm stroker? I will have the stock head, with bigger carbs. I figured after I putt the head on and tightened it down that the other cylinder would help hold it down. All 4 bolts held on the other side and all 10 head bolts torqued down to spec.
Do you think it will hold? If not What should I do to fix this problem? Bigger Tme-sert?
Suggestions are appreciated.
