finaltouch
finaltouch's Achievements
  1. would you do 200$ shipped to moncton NB? can paypal anytime or meet a trucker friend in mississaga
  2. look me up if you are stopping in moncton
  3. I would like to have seen the shamrock/ortiz fight go longer just to see ken get another good beat down, but I dont like ortiz either. just means he is one step closer to a beat down of his own. as for the pride guys comming over, I think it will make for some great fights, but i wont jump on the wagon thinking that ufc will rule them all. it will be a mix as there are some very good fighters at pride also. wanderle/liddel will be a great fight, but I would give the nod to silva just because he seems like a better package fighter, and is absolutely relentless. it would be nice to see crocop in the ufc, but he would be really lacking his trademark finisher, the soccer kick to the downed opponent. even still his kicks are dangerous, and I think that he would beat tim. also emilenko would be another great fight over here with tim. as far as matt hughes goes, not sure there are many that will stand with him in his weight class, but it would be a great match to watch if someone decent tried
  4. finaltouch
    kick start
    looking for a tight kick start lever, mine rattles bad
  5. im looking for the part number for the rear swingarm bearings at the frame. looking for an aftermarket replacement
  6. shee is running again, and i actually idles now. thanks guys for the information. now it is time to break it in a bit, then start looking at mods
  7. would have loved a new head but mine is already back on, and waiting for the rain to stop to try it out
  8. took the cyclinders to yamaha to be inspected, and then to an engine builder to be honed, they both said it was fine
  9. well heres the problems that I found so far first when I pulled the head off it looked like some severe detonation on both the head and the piston, but when I pulled the cyclinder off it was clear that the top ring somehow got chewed up , so i need a new piston for that side. the sleeve miracously did not suffer too much, but the head is probably toast. heres some pics of the damage also the top ring on the left piston was pretty seized in place, and I broke it trying to free it up \ so what suggestions do you have as far as replacement parts, or better parts. might as well do it ring the first time
  10. just want to get it to run right first. checked the compression, and it is 30psi in the right side, and 70 psi in the left
  11. I have searched and done alot of reading, but still havent figured out the problem. I just bought a 2000 banshee a couple weeks ago. initially it worked great, then the last trip out the throttle stuck about half way, and it would pulse hard. I tried to limp it home, and ran out of gas about 5 min from home. I took the carbs apart to find that one had the top tors peice loose, and it had gotten dirty enough to make it stick. I cleaned this carb, then looked at the other one, and cleaned it at the same time. I put it all back together, and it wouldnt start, so I pulled it with my other wheeler. I could get it to start but wouldnt run well. so I checked the plugs, great fire, . when it is running, the left pipe has hot exhaust, and the right is cool. I also swapped the plug wires same . left is hot, right is cool. It seems to me that i am getting fire, but the right side is backfiring, and barely burning as the exhaust is really cool I have now taken the carbs of 3 time to try to clean them with no change. any ideas on where I should look next?
