caleb_yfz350
Everything posted by caleb_yfz350
  1. i took mine off and now my bike runs like crap. they say the circuit isn't closed. i didn't know there was anything electrical involved with the p- brake. but since i removed it my bike won't run
  2. well i connected the two wires, still wont run right. disconnected the tors system. didn't make a difference. is there something else i am missing, something electrical? my friend said mabe i need to dissconnect something under the seat. or am i not getting the wires connected right. what way should i connect the wires? i just wrapped them together tightly. its gotta be parking brake but mabe im not fixing it right. any suggestions?
  3. i'll check it again. that is exactly what it is doing. right above idol. my computer was tweekin and it posted my reply three times, sry.
  4. i removed the wires from the pirtch, cut and connected them. still wont run right. it sounds like that is the problem though. thats all i did since it was running. which was only a couple months ago. also when it isn't running i had it in gear and pulled the clutch and tried to push the bike and it wont move. but when i had it running i pulled in the clutch and popped it in gear and it just sat there. sounds like the brake system. this all happend once i removed my parking brake i removed the wires from the pirtch, cut and connected them. still wont run right. it sounds like that is the problem though. thats all i did since it was running. which was only a couple months ago. also when it isn't running i had it in gear and pulled the clutch and tried to push the bike and it wont move. but when i had it running i pulled in the clutch and popped it in gear and it just sat there. sounds like the brake system. this all happend once i removed my parking brake i removed the wires from the pirtch, cut and connected them. still wont run right. it sounds like that is the problem though. thats all i did since it was running. which was only a couple months ago. also when it isn't running i had it in gear and pulled the clutch and tried to push the bike and it wont move. but when i had it running i pulled in the clutch and popped it in gear and it just sat there. sounds like the brake system. this all happend once i removed my parking brake
  5. when you blow it, or when you've tried everything else and have no other choice, or when you want to modify it. its fairly hard to do if your not use to working with engines
  6. i recently bought a parking brake block off plate. i removed the parking break cable and pirtch setup. that is the only thing i did since the dune trip. could that be the problem? what is the TORS system?
  7. my banshee was runnin just fine i took a dune trip a few months ago and she ran like a champ. i try and fire her up the other day and it will start and idle, but when you give it gas it just kinda boggs and makes a throaty sound. i have brand new gas/oil and spark plugs. help me. is it my carbs? mabe they are clogged or something?
