Breton
Everything posted by Breton
  1. Thanks alot...some one told me the engine might over heat without the overfill tank..is this true..or does your banshee run fine without the tank? Thanks again, much appriciated
  2. I just recently took apart my shee to paint the frame. Now that i have it all together im having trouble remembering where the coolent lines go, i have all the main lines from the pump and head to the rad..but its the small overfill lines that im having trouble with. I cant remember if there is an air vent line, and where it attached to, and where the lines for the overfill tank are supposed to go. I have it hooked up so the top line from the rad, goes to the top connection on the overfill tank, and the drain line from the overfill tank goes to the T to the water pump and a line into the crank..but im pretty sure that isnt right, cause now i have a left over line...someone please help me..i wanna go riding soon! And sorry about the big A$$ story.. Thanks alot in advance
  3. I found out my master cylinder seal is leaking, but thank you to all that responded, i know what to do once i replace the seal. Thanks again
  4. I just put new rings and pistons in my banshee. Im having idling problems. Unless i am on the throttle or choke the engine wont stay running. When riding it it runs awsome, full power is there, but i notice it likes to rev once the throttle is let go and the clutch is engaged. Does anyone know what might be wrong? Im thinking my reeds might be done..but i have no idea..ive tried adjusting the idle screw on the carbs, but no matter how high i put it, the engine will not idle. Thanks for the help
  5. Can anyone tell me how to bleed the front brakes on a shee? Ive tried the whole pump it, then crack the bleeder then close it, but there is no fluid being pushed out of my lever box..does this mean i need a new brake box? Or am i doing something wrong? THanks
