Hey Guys, Im new to the Yamaha banshee, i recently purchased a 1989 banshee, its bored .50 over and has twin DG pipes. For some reason its spits and sputters and almost acts like it is firing on one cylinder when i am going up through the gears. It does it real bad through 3-4, but 5-6 are ok. I decided i would take the air filter off it and give it a good cleaning, but that didnt work. i then decided to run it without the air filter, and that solved the problem, or atleast most of the problem, still bogs out some, but not nearly as bad as it did with the filter. I am also running it 32:1 and i dont know if that it too lean. I am also running NGK BR9ES plugs, can you guys please help me with my problems, thanks alot,
Mopar 440
