lonestarshee
Everything posted by lonestarshee
  1. i am new with these machines and was wondering if someone can show me a picture of where the pilot air screw is. which way do you turn to lean it up? thank you
  2. i picked up the machine recently. v-force reed valves, pro circuit 304's, i believe the jetting is factory, carbs are supposedly larger, air box lid is cut. machine runs great when it wants to. im thinking of draining the fuel out and re mixing since another family member pre mixed oil for the machine and the oil content may be to high? i heard 32:1 is a good ratio? ill check out the plugs to see if they are black or not.
  3. hello, my banshee is bogging out from low to mid range. If i have the rpms higher it runs fine. Do the carb's need to be adjusted? i am getting fed up with these 2 stroke machines since there is always tinkering to do on them. thank you
  4. should i use 50/50 coolant/water ratio for both the radiator and the tank under the seat? why are there two tanks? thank you
  5. hello does anyone know the model number of the light bulbs in the front lights? ive burnt one out and cant seem to find a number. is the rear bulb in the tail light a 1157 bulb? Thank you
  6. thank you very much guys!
  7. the a arms dont look to pretty and was wondering if anybody painted theirs themself? could people post some pictures of what they have done, thank you
  8. hello there, do you still have the nerf bars?
  9. i run amsoil oil. yamaha recommends 24:1 but isnt this a little rich? i have no engine mods but full procircuit exhaust, vforce reed valves, cut airbox, boost bottle
  10. i was wondering what the mix ratio was on the banshee. forgot what it was over the winter! is it 24:1?
  11. i was wondering because on the arctic cat firecat snowmobiles, if you remove the lights, the CDI box will burn out
  12. i was wondering if i can take off the headlights and not blow the coil
