Hey all,
I have asked around on other forums about this problem but I still cant get it fixed. I have a 1990 banshee bored out to a 370 with toomey T-5's and single carb kit. I am running a CEL needle, 52 pilot and I think a 162 main jet in a keihin carb. I am running 132 left and 137 pounds of compression in the two cylinders.
The Problem:
The Shee starts and runs fine but when you go to rev it up a bit it boggs down and refuses to rev up. After a few seconds it revs up but is still bogged down like the motor is loaded up. If you run the machine in the first two gears it still wants to bog, but after your in 3rd and up and you are in the meat of the power band it really screams.
I have a honda 250r that is all stock and it revs out like I believe that the banshee should. I have worked on snowmoblies all my life and I just cant straighten out this problem. The wires are all tight and have a good ground its just having issues at the 1/8 - 1/4 throt.
Any help would be greatly appreciated
Adam
