alien
About alien
  • Birthday 12/12/1959
Contact Methods
  • Website URL
    http://
    lucedale ms (25 miles from mobile ala)
  • Interests
    fishing, riding my banshee,spending time with my wife and kids.
    1996 banshee, blue raptor custom plastic, green frame, 4 mil stroke,5 mil long rod, cool head 21cc domes, dmc alien exaust, itp wheels, holeshot tires, ac nerfbars, front bumper,and grab handle,uni filters,boyesen reeds,boost bottle, fly handle bars and grabs.
alien's Achievements
  1. guys i really appreciate the help. i have read maaaaannnnnyyyyyy of the other forums on here. my wife says what are you looking at bhq? i had considered the info yall have gave others. i am 41 have a cool banshee that i enjoy but still have some learning to do. i almost didnt even post but i am glad i did. when i fine tune my jetting better i will report back with my findings.
  2. i have the dynojet kit and will put it in when i have time. it has 340 main and the new needle. i think it will be lean but we will see . ill report when i do. thanks.
  3. i appreciate the input guys. i will look closer at my plugs and check for a air leak.
  4. what i did was clean the exhaust till all the blemishes were gone. i cut the divider in the intake down to about one sixteenth on the edge close to the carb and the edge close to the cylinder is still stock width. i cut on the transfers from underneath the jugs and rounded the edges. i did not do much because what i read on bhq i could make my engine worse. i hear so many different versions of what my jets should be so i figured i would post here and ask . i did a wot and my plugs were about the color of dry pine straw. right now my banshee runs good, no bog. i dont have any other banshee experience to compare to. on the dyno it peaks at 8800 but did turn 10700.? me and my brother plan to experiment with jets and see what it will do. i have a dynojet kit now but have not put it in yet. i rebuilt the engine with new crank, pistons, seals, gaskets, clutch,head ect..... it should not leak but anything is possible. i may have ran three or four tanks of gas thru it. :baseball_innocent:
  5. it does run fine. i will check for a leak, thanks.
  6. i have dmc aliens. i like mine but that is all i have owned.
  7. undefined Hey guys i would like to know what you all think would be close to the right jets for my mods. I have done several searches to get a general idea but wanted to list my mods and see what yall think. I have a 96 banshee, 4 mil stroke,21cc head ,66 mil bore,dmc ALIEN pipes and silencers,boyesen reeds . I cleaned up my ports and rounded the edges. I am +3 deg and have pod filters. I am at 1000ft elev. right now i have stock carbs,420 jets, third clip on stock needle and 30 pilot. It seems to run great. it dyno,d at 57 horse. does this sound ok? A friend reccomended the stage three dynojet kit but it comes with a 340 jet?
  8. undefined Hey guys i would like to know what you all think would be close to the right jets for my mods. I have done several searches to get a general idea but wanted to list my mods and see what yall think. I have a 96 banshee, 4 mil stroke,21cc head ,66 mil bore,dmc ALIEN pipes and silencers,boyesen reeds . I cleaned up my ports and rounded the edges. I am +3 deg and have pod filters. I am at 1000ft elev. right now i have stock carbs,420 jets, third clip on stock needle and 30 pilot. It seems to run great. it dyno,d at 57 horse. does this sound ok? A friend reccomended the stage three dynojet kit but it comes with a 340 jet?
  9. they are a pain. i had to use longer bolts to go in the front and put nuts on the inside to hold the front support bracket. bolt your peg stub first and slide the bars over them. i had to use a board or something similar to tap the two halves together in the front.
  10. I have raptor plastic. I do like them . The problem is no one makes graphic kits forthem.
