823REDHORSE
Everything posted by 823REDHORSE
  1. i cleaned both carbs pilots and mains, it seemed to help a little bit, but still acts the same. i will work on it some more this weekend.
  2. i just put brand new v-force 3 reeds in it so i would hope they are not bad
  3. well guys i put new plugs in it the day it started this and i run her pretty hard the whole time. so i just figured that it wouldnt need any but i guess it could. would it be possible to foul them that quick? they look fine. they are clean, but i will try new ones. the reason i didnt put new ones in it was cause they look so good
  4. sorry for confusion but i came straight in from working on it and was so pissed off that when i typed it came out all wrong i dont even understand either!! it gets plenty of fuel to the carb and i never touched the float choke tube on the snorkel is off thats it new plugs i just cleaned both carbs and it will start on its own now but the left side pipe blows crazy smoke and the right really only seems to run at high rpm's and the right side pipe barely gets warm remember it ran great for about 2 hours after install of new parts then just started acting foolish the black box has been unplugged BLACKANDYELLOWSHEE now that you mentioned it i think it did seem to hit a little better with choke on
  5. i cleaned main jet only in the right carb. the left pipe gets hot and the right doesnt except if i put fuel in the back of the carb where the air filter goes. and that is the only way it will start also elevation is almost sea level i live in nw florida
  6. if i squirt gas in the carg it runs and blows exhaust against my hand so i dont think its silencers and if it was reeds would it run by squirting fuel in the carb?
  7. first off i want to say sorry so long but i want to try to tell all i have a 1999 stock, i just put pro circuits, jets 300, third ring on new needle,v-force 3,boost bootle, and uni filter. my problem is i rode it the other day for about 2 hours run like a top out running modded honda 450r, then all the sudden it started bogging on the top end and i noticed that the right side pipe was cool. so i put it on the truck and went home well the next day i went out to hopefully fix the problem but it wont start. i checked compression 120psi on both sides. checked spark good on both. so i got a spray bottle pulled air cleaner out sprayed fuel in the carbs and she started and run but only the left side blow a little smoke and pressure against hand nothing on right side except while squirting fuel in air box. took right side carb off and cleaned main jet it had some dirt in it but still the same thing so any help would be REALLY HELPFUL!!!!!
