bkdamkr
bkdamkr's Achievements
  1. Great! Thanks for the answer - two different overflow tubes! What's a "choke crossover tube"? I noticed that only one carb has a choke on it, so I assume that the crossover tube links the two carbs. Where does it attach? Thanks again, Brian
  2. I don't have the tubes, or I'd follow them. All I have are carbs that I'm trying to plumb. I have fuel inlets, and some sort of short overflow tubes up higher on the side of the carb, and then these nipples on the very bottom of the float bowls. As soon as I know what they're for, I'll be able to finish my plumbing. Thanks. Where do yours go? Brian
  3. Puhleeeeze - what is the purpose of the tubes that attach to the bottom of the carbs' float bowls? Where do they lead? What do they do? Anyone want a free throttle cable assembly with the, what is it, TORS? gizmos? I just bought a complete setup and only need the raw carbs. Send me an address and they're yours. Thanks, waiting impatiently but hopefully... Brian
  4. I have a pair of Banshee carbs with a multitude of hose attachment points, but no hoses. From what I can find on "Parts Fish", two are apparently vent hoses, which leaves three. One input is ~6mm diam smooth tube with a "knob" on the end, which is bent upward. The second is a smaller, vertical tube with ridges, which points upward from around the carb waistline. The third is another ridged nipple, though horizontal, which leads sideways out of the bottom of the bowl. When I got the carbs, these bottom nipples were linked together and another hose "T'd" off of the one joining the carbs. So - where do each of these go, and what purpose do they all serve? Thanks, Brian
