gforce15
Everything posted by gforce15
reeds look good you can see a very minor amount of light through them no missing petals none are cracked
ill try that I have 2 other banshees to pull from. the wiring harness is stock with all tors and e brake crap unplugged. kill switch is the stock one
that's what I was thinking of doing I wanted to see if you guys had any ideas that I have not tried before I went that route. I do appreciate the ideas
did a leakdown passed that holds 7 psi for way longer than 7min. have not inspected any seal on clutch side. I saw it with a bore scope camera and then flipped it up side down to get it out. the fluid was in the crank valley under the rods. right where cases get trenched. after you kick it and it trys to start it will push air and smoke out of the carbs
tried that to no luck
421 wampus refuses to start. bought it from a guy was not running apparently he had just built it. got it home clean the carbs put new plugs in and it started an ran good. pulled it apart powdered the frame put it together and it still started and ran good. left it alone for a week was going to ride it and it would not start. I have checked all grounds tested stator, coil, and swapped cdi with a none good one no luck. did a leak down passed that. has 150 psi on both cylinders. carbs have been cleaned and floats adjusted. noticed there was a grey milky liquid at the bottom of crank turned bike upside down got that out. I kick it over it try's to start and occasionally will half ass run for a second and dies. when the plugs are in the motor and I kick it they do come out a little wet but not bad. ive tried 4 sets of plugs. also have checked pick up coil distance that's good any thoughts
have a set of dpi oof sf ss has one broken spring mount they are chrome in good shape 250 also have a set of dg inner frames good shape chrome 175 shipping is extra open to reasonable offers
i have a good used rear shaw that is 13-1/2in looking for 150 obo will send pics by email
looking for some sb outer frames for the banshee
i have a set of new miere plastic white front piece and carbon fiber looking tank piece looking for the same two pieces in black that is in like new shape like mine let me know what you got
email sent
For sale i got a set of very nice cpi inner frames, they have no dings very nice chrome with chrome hangers can send pics by email 420
looking to sell or trade my cpi inner frames for a nice set of outter frames. mine are all chrome and very nice with chrome mounts can email pics
when you convert to alcohol do you need to change out the domes. and is there anything else that needs to be done besides cabs and plugs that needs to be changed
looking for a set of alky carbs around the sizes of 35-38 got 35 gas kiehin right now
looking for a rear marvin shaw for the banshee
what is need to convert to alcohole from gas. is there kits to buy or just bigger needles and jets
looking for a good rear banshee shock or marvin shaw
why yes it is a rack and pinion set up also has a fuel cell and a king pin front end set up and seats and some extra little parts
located in collinsville il
what is done to the motor i assume its a banshee motor
i have two buggy projects up for sale or trade one is a single seat buggy with a zx11 street bike motor in it the carbs need tuning and a throttl cable needes to be installed the buggy is 90% done lost intrest got raped up in drag banshee project the other is a two seater chop top buggy bare frame asking 2000 for the single seat and 1200 for the two chop top buggy open to trades for banshee parts motors manily or whole bike or a 450 of equal value can send pics just let me get ur email
i have an 04 yamaha r1 motor for sale or trade for a banshee motor of equal value looking to get around 1000 motor runs god and have wiring harness header and gauges and radiator
