sarider
sarider's Achievements
  1. New crank, top end, and degree key were the only differences. How do i do a pressure test?
  2. Found a crack in the intake boot, replaced it with a new one, put everything back together and same problem. Any other ideas on why it would be revving so high? Thanks
  3. intakes seem fine, took them off cleaned them, put alittle bit of gasket sealant to be sure and tightened them up. Same problem
  4. I cleaned the carbs out, and that didnt help. The slides are in sync. Ill check the intakes for an airleak.
  5. Hey just rebult the banshee. It starts easy(2-3 kicks) but it revs to the moon at idle. Throttle cable isnt pinched, and adjusting the idle on the carbs doesnt really make a difference. Any ideas of what the problem could be? Thanks in advance for the help.
  6. Title says it all. Right rear hub on my shee wont come off. Ive tryed just about everything i can think of and it wont budge. Heat, pb blaster and it wont move an inch. Anyone had this problem before and have some advice on how to get it off? Thanks in advanced
