HarleyDave
Everything posted by HarleyDave
  1. Well not so fast. Talked to the Kid. He has changed out the Thumb trottle and put on the twister modded the carbs. So with this MOD, the Tors is disconnected, Right? Dave
  2. Thanks Guys I will get it today Have a Great New Year Dave
  3. Looks Like I may have found the problem and saved $60 dollors in diagnostic fees TORS(Throttle Over Ride System) the main purpose of this is to keep you engine from blowing up if one slide gets stuck in the open position. There are sensors on top of each carb that senses the position of the slide in the carb. There is a sensor in the throttle housing that senses the position of the throttle. The sensor in the throttle housing and on top of the carbs sends a signal to a box(Located under the gas tank on the left side of the frame). When the position of either carb or the throttle position and carb slide positions don't match then the box will send a signal to the ignition box and the ignition will be adjusted to keep your engine from blowing. In another words......get rid of it because when it gets wet enough it will reak havoc and become a huge headache. Plus when you get rid of it and put in a TORS eliminator kit the throttle response becomes alot better. It ran fine 2 days ago, then yesterday my Son washed it.
  4. No, I did not disconnect anything but the connector from the lever switch. Now I have to ask.....TORS?
  5. Hello All, Hope someone out their has an answer to my prob. My Banshee will start and idle but it has no rev. Acts like the parking brake is on, but its not, I even disconnected the wiring to it. I traced the wiring back to the CID module, Could that be the Problem? Please help if you can. Thanks Dave
